![Bild](http://img519.imageshack.us/img519/4697/tachoko8.jpg)
![Bild](http://img519.imageshack.us/img519/tachoko8.jpg/1/w800.png)
Harness H - (10-pin connector; I used the green 10-pin connector from my stock 93 dash harness that connected to the bottom left of the original gauge cluster)
1. Yellow -- power
2. Pink -- speedometer
3. Yellow -- power
4. Red/Black -- dimmer wire
5. Black -- ground
6. Orange
7. No wire
8. Light green (you need to splice the wire from the dash clock harness & run it to the pin) -- trip mileage memory
9. Red/black dots blinkers
10. No wire
Harness J - (5-pin connector found on most Honda power window connector harnesses, but since only two wires are needed to be connected, I used a 2-pin connector from a computer motherboard fan)
1. No wire
2. No wire
3. No wire
4. Green/yellow -- right blinker
5. Red/blue -- high beam
Harness M - (5-pin connector; I used the yellow 5-pin connector from my 93 stock dash harness that connected to the top of the original gauge cluster)
1. Blue/silver spots -- tachometer
2. Black -- ground
3. Red/yellow -- high beam
4. Green/blue -- left blinker
5. Blue -- SRS
